2G Big problem, cut at WOT
Heryst78
119
11
Feb 9, 2017
Paris, Europe
Hi guys
I come to you because I have a big problem with my GST eclipse of 1997.
the problem is that when I acclimatize, arrived at 4000 rpm, the turbo cut, and I feel that my engine exploded.
I read on the forum that there was the phenomenon of "fuel cut" which could produce this sensation, as if I entered a wall.
however, the engine of the eclipse is original. I have only one system of exchanger, and a boost controller closed thoroughly.
I have 1 bar to my boost gauge, and the AFR is perfect (14.7 in slow motion, 10 accelerating at bottom so not poor at all)
Has someone already had this problem ? it only happened to me once but it worries me.
injectors, gasoline filter, air filter, everything is new.
the only problem I have on the car is my throttle position sensor that sometimes goes into default. I cut the engine and then I restart and the CEL is gone.
thank you :)
I updated my profile :)
I put a picture of my car :)
yes, i am from paris in France, I use Google Translate to write to you :)
I presume that by Mods you mean the engine parts I have no? :)
On the eclipse I have:
- An ebay intercooler with all tubes and hoses
- Turbo t25 of origin
- A manual boost controller
- Injen admission with a K & N air filter
- A dump Valve Forge
- A black turbo eprom
- Exhaust line after HKS catalyst
- An AFR gauge
- A turbo pressure gauge
for the original OEM parts, I replaced the throttle body, all the intake and turbo gaskets, the injectors are new.
I did a boost leak and no leak
the EGR is doomed.
and that's all :)
