Big enough compressor?
2GEffect6
180
Jul 21, 2011
Alliance, Ohio
is a 5HP 25 Gallon air compressor big enough to paint with? my guns run 21psi in and 10psi while the paint is actually spraying out
it will work but i would recommend a much larger compressor. the tank will loose pressure really fast with spraying hvlp. make sure to run a moisture separator before hose and at the gun also with a small compressor as you will get moisture quicker since it will almost constantly be running.
also make sure its a continuous duty compressor or it could overheat and pop the fuse on the motor till it cools off.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
