Big 16G Limits Info
forumboarder154
209
3
Jan 14, 2006
ypsilanti, Michigan
I'm getting a "Solution Kit" off turbochargers.com for Christmas and this is what I plan on getting for it. I am getting the
E16G sorry for the misunderstanding.
"Solution Kit Big E16g"
Evo 8 fuel pump (already rewired my stocker just so you know)
550 cc injectors
What is the max psi could I run? Also would I need an S-AFC and what else would I need?
-Kyle
youll need an afpr for the fuel pump, a wideband o2 would be a good idea, and definetly get a datalogger if you havent allready.
safc would allow you to tune your car so that would be a good idea as well
Why not get the EVO3 if it's the same price as the Big 16g?? (just curious)
You'll have to figure that one out yourself when it comes to the psi thing. It's case by case. BUT 20lbs will most likely be the max due to those injectors.
its true it really depends on your logger and afc, especially since your engine has nothing done to it u couldnt run more then 19 or 20 and I would say thats pushing it with out the right mods.
