Big 16g direct fit?
pitbull419
981
Dec 31, 2004
port clinton, Ohio
I might be getting a mitsu big 16g and a punishment racing o2 dump in a trade.
It has the 7cm turbine housing. Did this come with the turbo or was this an upgrade?
It has low miles
This will be a direct fit for a 1g car with no upgrades correct?
If not what else will i have to change?
Thanks
The gaskets will be set up for 7cm and your 14B is a 6cm so some of them will be different. I'd just make it easy and grab the install kit or talk to Turbochargers directly to make sure you get everything you need for an easy setup with no headeaches.
