better MAF
z24frank
370
Nov 26, 2007
san diego, California
Ok Im getting ready to install my evo MAS and my buddy says he has a Al Blaha 1g mass,which one should I use?
Well, Al's MAS got him in to the 10's, so it works. However, I think the EVO MAF will be more accurate. It has better technology for measuring air flow so you will get better results.
A better question is which forum should you post in, or how to navigate out comprehensive search function.
No more of these random question with no context will be tolerated.
What are your goals? What is your mod path looking like?
Moved to the newbie forum (yep Frank, another one)
How is that random?I asked a very straight forward question in the related topic section.It doesnt matter what my mod path is a simple question is still a simple question.I just wanted to know wich one works better before i go installing a lesser quality item on my car.So I dont understand what wont be tolerated?I thought this was a FORUM where people talk about cars and ask questions!
If you'd read the remainder of my response before flapping your gums in the wind, I asked two SIMPLE questions that take your question from a random question into a well thought out, simple question. That said, there has been much discussion over the years about what MAF/MAS to use for particular goals, experiences have been shared, etc.
Off-topic, rule breaking BS deleted and warnings handed out. Play nice, kiddos.
This was quoted from Wiseman 'Steve" on the forums referring to the 3g MAS which is almost identical to the EVO MAF hope this gives you some percentage on flow
The GOOD 3G MAS to find is the #482, from the Variable-Induction V-6. The #482 V-6 MAS flows so close to an EVO MAS that the 2 could be interchanged, and no one would probably notice. This MAS flows 25% more air for the same Karman Hz as a 2G, and 67% more than a 1G, so you have to add a LOT of air on an AFC.
