Best way to install return line on PTE's?
bmxrider154
160
5
Oct 25, 2004
Cincinnati, Ohio
When installing my Scm-5031 i ran into a few problems with the return line. I bought the return kit from forced performance and it was impossible to use the line provided b/c it would kink due to the tight bend. First it hits the front motor mount so i grinded that down but its still tight. I then had to use some 5/8 heater hose:shhh: due to its flexibility.I ended up getting it to work but not satisfied, so i am asking for some opinions/pointers on how you guys have gone about this. Im considering the slowboy kit that has one 45 deg. and one straight, but want to see if anyone has had success with that combo. Thanks.
-bryan
I run the 90/45 from SBR and it still causes a slight bend in the return line, but it is no where near from restricting oil flow. Ideally, the best way to do it is 2 45* fittings. This way the actual return line is straight and only bends slightly.
I agree 100%:thumb:
Awesome, thats what i was planning on using i just wanted to get a few ideas on top of mine. Thanks for the help guys.:thumb:
-bryan
I used a cut down fitting off the turbo, cut a big notch in the motor mount, and used the stock return on the pan cut down.
I tried heater hose but it swelled up and got soft after a week or two, now I'm running some nice silicon lined return hose.
-Seth
