Best 7 bolt rebuild kit
Nosroxs
150
Apr 16, 2011
St. Louis, Michigan
OK so i spun a rod bearing in my 96 eagle talon tsi fwd. so i tore down my motor and had it hot tanked and the crank cut and polished block honed brushed cleaned etc. i got a friend that is gonna build it for me since i don't trust myself.. anyways besides that. i need a rebuild kit.. preferably i want to buy it as a kit so i have everything i need. oil pump, pistons, rods, all gaskets, water pump, timing belt "preferably Kevlar", main and rod bearings, piston rings, and timing belt components, tensioner, pulleys etc and maybe head-studs but i figured id be buying arp separate anyways .. so basically i want a kit like this. >> 95 99 Mitsubishi Eclipse Turbo Engine Rebuild Kit 4g63 | eBay but not cheap where its gonna break after being built. i am keeping this motor stock as possible but still good enough to handle 14psi on a 14b turbo as a daily driver while i build a 6bolt for a 2g gsx project.
So question is.. is there a kit like the one on ebay that isnt as cheap but not expensive as hell.. and second would this kit be alright for a stock rebuild for daily driving?
Oh and yes i have searched this site and several other sites including mad searches on google ebay. EVERYWHERE and can only find what i am looking for on ebay, but have no idea what the brands are. All the posts on here are about rebuild kits for a 6 bolt in which im not trying to rebuild for this car. So please don't tell me to scrap it and find a 6 bolt. I like this car with the 7 bolt and going to keep it that way.. thanks for the concern tho..
Hmm LOL not the best response i was looking for but thank you.. Any others have any input?
DO you want stock parts? Or do you want to build it up?
If you want to build it up you will need to source the parts but I bet if you call a vendor they will set you up with a package deal.
If you want all OEM parts I would check JNZ for the parts. Or check the classifieds here probably could find a replacement engine for cheap. But depends on what you want to do.
If I were you I would just build it up since it is apart anyways.
Another thought, have you checked local parts stores for engine rebuild kits?
I checked the threads came across this Rebuild Kit?
