Best 1G N/T Injectors
Synapses
425
May 9, 2005
Dawson Creek,
What are the best injectors to get for my n/t without having to do any other changes? Do the 1G black top 390cc injectors work without any other mods? and does this get you any HP gains or is it just pointless?
oh ya, and my car is a 1992 6 Bolt 2.0L 5 spd
well ucould get some TRUBO 450cc inj incase you wanted to throught some nitrous on it. but if your sticking with plain ol' stock then there is no need.. if you want to do later up grades as in build the bock and what not.. it would not hurt. but if your staying stock its just like talong_boy said its pointless..
FYI,
The 1G AT turbo injectors have grey tops (the 390cc you mentioned).
The 1G MT turbo injectors have black tops (those are 450cc injectors).
.. don't know if either of these will actually benefit your stock NT though.
No benefit, plus you'll have to wire in a resistor pack to lower the impedance on the turbo injectors.
If so, how come the 1994 Talon ES SE only had the turbo intake cam and the 300cc injectors but had 167 hp instead of the 135 hp ? Is that hp gain simply from the cam?
Oh god not the Talon Es SE shit again, look they made a 4g63 motor in europe for the 2g nt's that we never got here. Most of the gains were from higher compression pistons and probably the cams. They added bigger injectors to be safe. Hell I made alot more than 195hp on my stock 450's but they put them in all the same. Your injectors will be just fine. If you're really worried that you might need new injectors and you haven't added forced induction/nitrous/ or high compression, then get a datalogger and find out. Hell you have no way to tune the larger injectors right now anyways.
Noone runs larger injectors with any hp gains on an nt 1g dsm without forced induction. There's just no point in it.
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
  • Wanted 2g Diff ring gear. Internal 98-99 Transmission
    98-99 Manual transmission front differential ring gear. MD770499
    • GIB
