Belt wont line up
Dsm42oA
38
Apr 25, 2012
Clisle, Pennsylvania
So I recently put a new motor in and now my one serpentine belt is squealing. And just by looking at it I can see the a/c compressor is too far in and the pulley is pulling the belt over onto the crank pulley. But how could the a/c be off by that much? I can't move it out. When I tighten it back up te bolts pull it back over. Thanks for reading, I'm confused
if you took the pully off it may have been put back on backwards. i know on the water pump that will move the belt 1/8-1/4 inch outta wack
sometimes easiest way to fix it is walk away and take another look tomorrow and it will make sense right away.
dont know how many times i fought to muscle something together to come back the next day and it slides together instantly
all belts have a tensioners your ac should not be off its bracket at all. tighten ac back up loosen ac tensioner pulley then put belt on, and tighten ac tensioner pulley until its taut.
    • Sdcryan1
