Bd1000Eclipse
Banned Member
- 756
- 0
- Nov 3, 2002
my arguement with you is done, your an asshole and you're wrong. I know it, you know it and so does everyone else.Originally posted by pballernh
Why not?
Why not?
mach v
Originally posted by MrPikolo
Btw laser, as fast1.8sohcDSM said, you should rebuild it with some performance parts, it would be better in the long run for ya.
Originally posted by fast1.8sohcDSM
So I finally am saying, don't rebuild your 1.8. Its not worth it. No don't try to turbo it, don't try to jump JE's in it. Its not worth your time. Seriously.
Fast 1.8's most recent comment was actually this.
And since you are serious about building your 1.8, you should special order the JE piston now because it will probably be a 1 month turnaround on them. Kalani and fast1.8 had to special order their pistons by giving JE the specs they needed.
. If you want to have a fast 1.8L, and prove to be a 13 second car, or 12, be my guest, but it isn't going to be easy. It is more worth it just going and buying a GSX and pouring your money into that ride. I like non-interference, non-crank walking, and distributor engines due to the lack in computer controlling. It is much easier for me to find problems with my car, then with a 2.0L 4G63/420A. I like my car, I want to make it a 12 second car, and I am going to spend well over 7,000 just in parts to prove I can be that fast.
