BCS Question
Prok0
Dec 25, 2003
Melbourne, Florida
Hey.. I have a quick question about the BCS, I recently installed a EVO III Big 16g on my friends 2G GST, and originally I had a T on the bov line, going into the stock T which went to BCS and WG actuator.
When it was hooked up like that it would go to 11-12psi and creep even higher...
So I removed the T going to the BCS and now it holds 10psi fine (which it should, since WG is set to 10psi)
So.. I was wondering if I need the BCS now that I put on the 16g...
Thanks in advance..
He has an MBC but its not installed... but I pulled off the T going from boost source to bcs to wg actuator and just ran a straight line from boost source to actuator and it ran a steady 10psi when we took it out for a test run and ran through 2,3,4th gear.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
