Battery Relocation
Brax93
69
Sep 9, 2012
lebanon, Ohio
Ive looked but haven't really found if this will work so I drew a paint diagram....well I'm going to get a battery box and put it in my trunk and I wont need a moroso cut off switch since I don't plan on racing at a strip. It will be all 4 gauge wire since I think its a good size and going bigger than that seems like really thick wire to use.
So tell me if this would work or does the alt. need a separate line?what size fuse 80 or 100amp?
Well I found a youtube video of a gsx relocation and I came up with this diagram of relocate.
Edit: just saw a post that the 420a are externally regulated at the ECU so are the 4g63 internally regulated at the alternator??? because that would remove the dedicated line for the alternator
So could I run a 1 to 3 Dist. Bock with fuses to the engine bay and split it up???
only 1g dsm is internally regulated in the alternator. The 2g regulates voltage via ecu
well I saw your thread also...im not going to have that cutoff switch but i came up with this diagram so far but tell me if this would work??
  • Wanted 6 bolt NT water pipe
    • chrisman287
