battery light !
alexrc
62
Sep 23, 2007
Santo Domingo, Central America
i have a question i have the battery light in the dash on ! the alternator is working fine , any ideaS? :dsm:
i done that and is working and chargin perfect ! its rare but is working good charges the battery 100 % if i disconect both plugs from the alternator the light still on as well
yes the tension is good as well , im runing out of ideas here , could be ground issue ?
Have you just installed anything electrical on your car in the past month?
Back in the original F&F days I used to have a set of LED Streetglow's under my car, and one of the wires was cut accidentally and then spliced back. A little while later it grounded out my whole car during a rainstorm.
Battery light is an early indication that there is some kind of irregularity in the charging system.
Your going to want to get a Multimeter and check the voltage's near the starter, fuses and battery when the car is off and again when its on.
Hi I'm rather new to this form but a battery light could be the voltage regulator which is located in the ecu. I no this because i had this problem i had to get a new ecu to fix the problem. But do u have a voltage tester of any kind if so hook it up. i also noticed that the temp gage was reading rong because i was getting 17+ volts when the voltage regulator went in my ecu. hope this helps peace munk
