1G Battery Parasitic Draw
Dsmpagan
126
5
Oct 29, 2013
Wolcott, Connecticut
I'm having a battery draw. Here's whats going on. There is a 1.8 amps reading on the meter at the battery before I start pulling fuses. When I pulled the 40 amp fuse under the hood labeled "belt" the meter went down to .2 amps. With that fuse stilled out I started pulling from under the dash. When I took the 10 amp fuse #4 labeled "automatic seat belt/headlight pop up switch it went down to .1 amps on the meter. Not sure what to do for the next step. It seems to be something with the seat belt but how do i fix it?
Thanks for any help
John
Bump
Still trying to get this resolved. You guy are usually really good about helping people out. Do I need to reword or explain my post more? Just looking for any help. Do I need to replace the seat belt motor or check to see if any wires got stripped and need to be fixed. I'm not really sure where to start on this problem.
Thanks
John
