brownfinger
- 1,957
- 11
- Aug 26, 2008
Normal,
Illinois
Like the title says...Does this make any sense to anyone? For the last year or two the car has been rougher and rougher on start-up. Finally got a FP guage (filter mount). Found out the rail wouldn't hold pressure overnight. Got a new FPR, too.
The other day I had the car in the garage, out of service for a bit. On a whim I disconnected the battery to reset the ECU. It stayed like that for about 48 hours. The following morning I noticed that it had actually held pressure overnight! By the following morning the pressure had actually gone up (ambient temp rose 20*).
Put the car back together, hooked-up batt., rail won't hold pressure more than a couple of hours again.
I'm mystified. The hard start is the least of my problems right now (unless there is a bad injector causing both symptoms), but I can't comprehend how this is even possible. How can disconnecting the battery make a fuel pressure leak go away when the car is sitting? Can a faulty ECU or relay partially energize an injector, or the pump, even when the key is off?
I haven't repeated the conditions to test if the rail holds pressure every time the batt. is disconnected, but this is the first time in 2 years the rail has held pressure overnight, and it held pressure for 48 straight hours.
Anyone ?
Anyone ?
Also I don't know the proper way to unhook the injector connectors. Mine were fubared before I got my hands on them.
. I"m also curious of a couple other things that affect start up. First compression test...I don't think I already asked. second is do you notice any exhaust signs? (namely white cloud at start up with coolant consumption..
But eliminate all the possibilities and tell me you did and how.
