Base AFR with FMU
david-b
562
Aug 15, 2005
Chicago, Illinois
Hey all;
So I've been turbo for awhile and been working on getting her tuned better. When WOT, my afr is reading on average around 12.0-12.5afr which is way too lean.
I'm using stock injectors, 12:1 FMU, SAFC and 255fp. Now I know this is a basic setup and a SFMU is best and blah blah... but my question is... with this setup and the AFC zeroed out, where should my AFR be sitting at? I heard it's supposed to be sitting around 10afr. I know other people here have very similar setups, so please help.
Unfortunatley a fmu offers no tuning what-so-ever. A safc can control your out of boost fuel but other then that its not a very useful on the 420a.
Your at 12:1-12.5:1 AFR under full boost (8psi?)?
With a 12:1 fmu I would say honestly thats pretty good. 11:1-11.5:1 would be ideal but for what you have I would say your sitting pretty good.
Sfmu is the best? Not quite....
MSnS. With PnP soon. Thats the best.
Well I know MS and all that is the best... but I was talking for my setup right now.
Full boost (according to gauge) is about 6.5psi. Not sure why that is so low neither. May be mis-calibrated gauge.
12s just seem way too lean to me. When I was N/A we dyno tuned for 12.5.
Like I said 11:1 to 11.5:1 is where you want to be idealy. But you have no real way of tuning it, so I dont know what you expect to do.
I was saying 12:1 is pretty good for using a fmu.
Did you get your fuel pump new?
And you said your boost gauge might be off?
Fuel pump is brand new.
Boost gauge is a GlowShift. When car is off and needle at 0, it's a little below 0 in vacuum. All the other boost gauges I've seen sit right at 0 when off. That's why I think it may be off a little.
