FMU Problems!!!!!
SUpracliPse86
Aug 9, 2012
Geneva, Alabama
Ok it seem as tho ive blewout the lower gasket on my fmu....i just installed it...ive been trying to tweek it because the FMU has been leaking around the fittings...when i took the fittings out i noticed that their were little rubber pieces broke off in the fittings....WHAT AM I DOING WRONG HERE?!?!?!?!?!
Take it apart and see whats wrong with it. Also verify that the boost ref port do not leak which would indicate a bad diaphragm
ok so i took it apart and yep the smaller lower rubber gasket had a hole rite through the center of it....and yes i believe its a cheapo....thing is hate to buy another one without knowing what caused this
