babyviper
- 607
- 150
- Feb 12, 2003
Mays Landing,
New Jersey
I am getting a 60 trim ball bearing full garret turbo this week or next and I was wondering how that would be on my setup?
MR down pipe 3" with custom catback
questioning a sbr manifold with an adapter or just going tubular
40mm wastegate
650cc or 750cc injectors what do you think is better
stock 7-bolt with a warranty
huge fmic 24"x12"x3" side to side with short route piping
255hp walbro pump rewired
safc
6-puck clutch
the questions are as follows:
1.) should i get a bigger downpipe because my MR downpipe looks like it merges from 2.25 to 3" to 2.5 then the cat back is 3" all the way back. o yeah no cat.
2.) go for the sbr manifold or a tubular because after the adapter plate the price of a tubular and a sbr Manifold are the same
3.)650cc or 750cc looking for 400hp without wasting excess gas and if knock will be too high i don't mind using wet injection gas is high.
4.)i know i got a 7-bolt but how would the motor act with that turbo on it (spool time, max boost, precautions i should take, things i should look for)
5.)give me some helpful hint things that will help me out or whatever
40mm wastegate
safc
6-puck clutch
