Balance shaft stub shaft in VFAQ work for 2G?
I just had this done on my 2g, stubby shaft and all. So I can easily say that you can use the stubby shaft. The ONLY thing that'll be different is one of the pulleys, after a certain build date (in 95 sometime I think) it was a bit different part) or so said the parts guy at mitsu
flinguist said:
There's an article in the DSMTuners tech guide, on balance shaft removal. In the article, you just cut off the balance shaft to make your stub shaft(s).
I'd rather do it the right way and get the stubby shaft from the galant.
