Balance shaft removal help
Saturdee
405
Nov 9, 2010
Duncannon, Pennsylvania
Does anybody know some trick I could do to get this phillips bolt off??? I almost stripped it cause it's on so tight, but its still fine. I just don't know what to do because it won't budge and I'm afraid if I try again it'll strip it completely.
Its an inexpensive tool that will create a divot in the metal of the Philips head screw. So that a drill bit will stay in place easier. The key is to get it right in the middle of the Philips screw. Then you drill straight down the center of the screw.
So putting a hole in the screw does what...
Nevermind. So when you drill down will it turn the screw or will it eventually just pop out?
You should replace the oil pump anyways! You got the engine apart, why do it twice.
Well I am being rushed through this so I'm just getting things fixed that needs fixed, and avoiding the "if I had extra money" things. Unless its like a manditory thing to replace the oil pump...
