balance shaft eliminator kit....
5150
167
Nov 21, 2004
Vacaville, California
ok so i installed the balace shaft eliminator kit the other day, got it all done and took the car around the block, came back and did a boost leak test and the next thing i know the freeze plug you get with the kit pops off and i have a massive oil leak. I know why it poped out and thats because i got a decent amount of blow by around the rings. Now i installed it the way the vfaq write up says to install it with some jb weld to hold it in. So i want to know if theres a better way to keep it in there. And yes i did let the jb weld dry.
OK, you don't just put it in there and call it done, i got this stuff from permatex called indian head its a sealant, and it seals and holds it in there and works fine, no complaints frmo me after couple hundred miles.
well i did use jb weld its possible i didnt use enough, where did you purchase the indian head because i dont think you can order it directly from permatex. Does Napa, Kragen, or Auto Zone carry it?
well i did use jb weld its possible i didnt use enough, does permatex have a site?
Permatex
How long did you let the JB-Weld set for? It is possible you didn't use enough. For example, with my kit I was able to insert the freeze plug without any effort. So I made sure to use plenty of weld to fill in every space in between, behind, & in front of the freeze plug.
It works just as well, You Juse have to be careful not to use too much, it can brak off when dry and clog up an oil passage, IT has happened alot before haha.
