balance shaft eliminated
602gsx
72
Dec 19, 2010
phx, Arizona
hey guys, this is the first time deleting the balance shafts im pretty much done with it just want to make sure with you guys if the 3 holes by the plug would/will leak oil. thank you
Which 3 holes are you talking about? Are you talking about the ones that hold the case to the block. IF you have bolts in them and the bolts torqued properly than they will never leak. Make sure to put a bolt in the hole where the balance shaft tensioner was.
