damageinc0318
- 44
- 0
- Feb 12, 2011
Elizabethtown,
Kentucky
Ok well I am pretty sure I messed up big time, I rebuilt my motor 2g 7bolt , I installed the balance delete kit. I started and the motor ran great for 10 mins or so . Then on a very light rev the motor died and the oil pump locked up. I kept my eye on my oil pressure and coolant the whole time. The oil pressure was pretty high, close to the H the whole time. After pulling the oil pump cover off the stubby shaft was seized to the oil pump cover. I am assuming the high oil pressure killed the stubby oil pump shaft. I did not do the oil filter housing port job . IS that my cause of the stubby delete shaft seizeing or do I have other problems.
well Guess I learned my last ebay china junk parts lesson for the last time
. Being poor sucks I can never afford the good stuff.
. Bad thing is we just built 2 motors and used the same balance delete in each motor. One is already in the car the other is still on the stand. Guess I am pulling the junk one out and let my buddy know about the one in his car
