Bad turbo seals?
DSMcrazy3
N/T DSM Wiseman
DSM Wiseman
2,196
62
Dec 29, 2004
Humble, Texas
Ok, when my car is warm, if I sit with the clutch in, and rev to about 2000 rpm blue smoke will pour out of my exhaust. :cry: I have a feeling it is the turbo seals, but i'm not too sure. I don't see why it wouldn't burn oil all of the time :confused: . Occasionally when I come to a stop it will burn oil in the same manner.(So it isn't just while revving)..Anyone had an experience like this.
I feel as if it's turbo seals because I just had my head taken apart, and certain parts replaced, including all valve seals.
Thanks for the help
I told you to do that leak test and you didn't listen. :p
1. Have you check the turbo for shaft play, licp and ic for signs of oil leakage.
2. Did you change the valve guide as well as the seals?
3. Have you done a compression test?
4. Have you check the pcv valve?
5. Is your crankcase properly vented?
6. Have you done that leak test yet?
  • Wanted 6 bolt NT water pipe
    • chrisman287
