Bad TOB
BLACK'98DSM
Moderator
5,519
3,051
Feb 9, 2019
Alabama
At idle there is a decently loud growling/rubbing/rattling sound coming from the transmission. But when I push the clutch in it pretty much goes away, and my idle feels a little less rough. My only thought is the throw out bearing, but could it be something else?
Sure, it could be an input shaft bearing or even a gear cluster in the transmission thats got damage, when you push the clutch in you remove the power transmission through these parts.
I forgot to mention that this happens in neutral, so the transmission is not in gear. TOB or input shaft bearing it is!
Ok, actually this is not the throw out bearing. Now that I actually take a moment to think about it, the throw out bearing would make more noise when the clutch is pressed in, because that's when it's under load. But my trans makes less noise when the clutch is pressed in.
Same. I am stumped on what this is. I did a little googling for like 5 minutes came up with a couple possibilities but I forget what it found LOL.. go figure
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
