1G Bad MAF??
boost_dependent
77
Jun 9, 2003
I have a stock MAF on my car and I just did a complete engine rebuild. I have had nothing but problems .. I just got my ecu back because it was all jacked up. Well i pluged it back in and the car will not idle. when I first start it up it goes to about 2k then tries to go back down to idle but just dies when it gets to about 900 or so. and if I give it gas it's all F***** up like it has a delayed reaction??? all 4 plugs are black and smell like fuel. How do you tell if your MAF is bad??????
sounds familiar i was thinking about checking mine to see if thats whats wrong with it... you might try just disconnecting it all together and seeing if will idle then...
has anyone got a way to test the MAF???? My car will only run for like maybe 1 1/2 sec or so LOL!!! i can keep it running if I just keep tapping the gas over and over..... but if I try to floor it or just hold it steady it dies as well???? I really need some help here. Also I have already ohmed my ISC and it had 29 ohms on all pins. I have blocked off my EGR... tries messing with the BISS... sealed the BISS..... I had my ECU rebuilt thinking that was the pronblem(and it was bad) that didn't fix it??? Please some one help me out here.... I know some one knows something!!!!!!!!!!!!!!!!!!!!
i found how to test the MAF
it said it was supposed to be like 2.8 ohms and it was nothing until i put the meter on 20K ohms which is a lot then it read like 3.7k ohms which is wrong.... so i left it disconnected and started the car and the mofo idled pretty much perfect.... i let it idle for a while then plugged the MAF back in and the car stumbled and died! So would that mean the MAF is bad?????
so ur car idle perfect with ur maf unplugged?:confused:
well it wasn't starting at 2k and going down ...down.. down dead! it started right up at about 1200k then idled around 800-1000 up and down a little... i let it do that for about a min then pluged the maf back in and it just stumbled a little then died! So does this mean that my MAF is bad or what?
