2G bad MAF?
JuGs
674
Jul 20, 2008
Marshall, Wisconsin
Ok I'm throwing 3 codes in DSMLink. IAT malfunction, barometric malfunction, and air measure malfunction. At least I think that is what they are called. I'll have to look at link again tomorrow to verify but is close to all them. From my research that all has to do with the MAF. It's all built into it and hench why in throwing those codes.
if u have a multi meter check the maf connector pins to see if the maf is dead
forget with voltage should b but its in another forum fr sure
Hey bud:
Yeah they all have to do with the MAF. Id start there man. Swap that bad boy out. Did you get it wet/ingest water? May be able to clean it out with electrical contact cleaner. Either way, tons of 2G MAF's out there.. Or you can MAF trans it, or DSM link V3 and run speed density. Either way, your on the right track. Start there.
Hope that helps!
Aaron
Yeah i might just go back to my gm maf. im sure theres some locals aroind here that will let me get a maf from them. i thought about goon sd bit i ###### wont till i get my holset setup going
Shot i posted in the wrong thread.....well i changed the maf n still same results. i didnt have a laptop to check codes ill check them tomorrow
Ok i checked the cel and now its just throwing p0443. i knlw this is for the egr system but i had remove all that. what is making my car to not idle? with maf unpluged it idles fine but drives like shit.....its not throwing maf codes now but still having idling issues
