stock MAF bad?
JKenyon22
Feb 8, 2006
Rockford, Illinois
I recently have been having what seems to be a "fuel cut" as i go past half throttle. I told a buddy of mine what it was doing and he seems to think it is the MAF. Now he told me to look for a corvette MAF, he said they work awesome on an eclipse, I have a 95' eclipse turbo w/ T-28 running around 13 psi. Is that sound like the problem and would a vette MAF work and perform good? I should probably let u know that I have stock fuel pump,stock injectors, and no FPR. What should I get or can anybody tell me what the problem is.. Thanks guys
I Have the same problem but I threw a code...maf ground malfunction.... would mine be bad?
Try a different MAF if you have one around or can barrow one. It also wouldnt hurt to look at your MAF and make sure everything inside looks normal( no broken wires).
