bad fuel pump?
bowens1414
123
Oct 30, 2012
Bradenton, Florida
Ok, so recently ive been running lean in boost and bucking, when car is warm. its not fuel cut though. also lately within a few months the car takes 5 to 10 seconds to turn over. i feel like its unrelated but about a week ago i got an exhaust for my car off ebay but the guy sent the wrong one so i had to delete the cat and could only straight pipe to the axle, and i had to cut off the second o2 sensor since i could not get it out. checked for boost leaks and the intake couple right on the turbo inlet had a crack. i tried to fix it best i could but dont have the money to buy new couplers :(. so im not sure if boost leak which i doubt or fuel pump or something different.
Unfortunately our engines do not have a fuel rail test port so you must tap into the fuel line somewhere after the fuel filter and before the fpr. The manual shows a special adapter that you place inline where the hose meets the fuel rail. But most people get this kit: [ame]http://www.amazon.com/46054-Fuel-Pressure-Gauge-Set/dp/B000CIKCG2[/ame]
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
