bad boost leak!!!
gsxin
76
Jan 13, 2005
McCook, Nebraska
I just boost leak tested my car and air is coming out of the turbo is there any way to fix that? I cant even find any other leaks cause its leaking so fast.:mad:
I think it might have leaked through the valves. cant seem to set the cams right for boost leak test.:cry: maybe I should work on it a little further before I post a problem. 30 degrees after TDC right?
We would all be compaining about sputtering on boost and slow spool! LOL "boostleak test? what's that?"
I run my boost leak tests at TDC (crank timing). I don't know if this is ideal. I can't picture in my brain a moment in crank degrees where all the intake valves are closed. Though this would be ideal to run such a test.
gsxin said:
old man what would I do with out you
I was hoping you would know to use proper capitalization and punctuation.:D
There are no position where all intake valves are closed, one set will always be open which means one of the combustion chambers will be part of a boost leak test. TDC is actually the worst place to be during a boost leak test because when #1 is in TDC, #4's valves are overlapping causing pressure to leak right through the combustion chamber straight out of the exhaust valves, 30* ATDC is about where overlap ends.
:thumb: Thank you.
