Back to stock tunning, need help
18Ace18
107
Apr 24, 2010
Hialeah/Miami, Florida
So I just finished my 6 bolt swap, and I need to set the tune on dsmlink back to stock so I can drive the car.
How do I set everything in link back to stock??
Another question, can I drive the car without setting the ignition timing?
you can set the sliders back to 0 and on th config. there should be a tab at the top you can click that will show you the stock settings.. Might want to check ecmlink.com on the forums as well if anyone has a stock log you could copy over to the ecu...
I am actually looking for a stock log myself jsut to make sure everything is set back to stock as I bought link used.. :)
Setting the base ignition timing is kinda important, if you are like 10degree plus in timing it could be very bad, same the other way. Be on the safe side and rent a timing light and do it.
