B16G Fuel ?
boostyGST
325
Aug 11, 2004
Flintstone, Maryland
Just wondering if when I install my B16G what are the limits with running it on stock fuel w/rewire untill I get my SAFC/injectors/pump.
Tyler
Tyler
I ran mine at 15psi under the advice of Dave Buschur and had no problems. Keep it at 15 or a bit lower and you should be more than safe.
Hope that helps,
Andy
I have mine set at minimum 11psi. Any higher and I would start knocking at the top of 3rd gear. Unless you're monitoring o2 or EGTs, it's gonna be hard to know what your limits will be as every car seems to differ. Note: I'm running a 1g. Will be nice when I get a new fuel pump.
