silkcity100
- 99
- 0
- Feb 23, 2003
paterson,
New Jersey
ok, with all the research I've done i found out that the B&M FPR can only raise pressure and doesn't lower, but why would you want to lower it more than 38psi, which is stock with the vac line off 43.7 with it on, since the stock FPR raises the pressure when it senses boost like the expensive AEROMOTIVE AFPR or the SX units?
Also found out that the stock FPR with the BM gets over run if you have a Walbro 255 cause it has a small hole that goes to the return line, so why not just drill that hole bigger?
If anyone has done this let me know what size to make this hole or if anyone knows what size it is on the AEROMOTIVE unit, TNXX
what happened to all the smart folks here no clue on this one
