Fuel Pressure Regulator
youll 10an to 6an coupler fitting 6an straight push luck or hose fitting , 90 or 45 degree push or hose fitting, 10an plug, 1g fuel rail adapter 6an ss line or push lock hose. and then a way to hook it up to a return line. it will cost about 80-150 bucks. summit racing and stm are good places to get these peices. i recommend doing something from the filter to rail. if you do and use the stock filter youll need a 6an 12mmx1.25 carb fitting.
