Axle Problem
Wheels-a-turnin
225
Apr 1, 2003
troy, Michigan
Ok, heres the deal..... I have a 2g with a 6-bolt swap w/air cond. removed
Well heres the problem i face. The front driverside axle is rubbing against the Oil pan. im wondering normally on a 2g is the A/C mounting bracket normally where the axle bolts to the block. If so i imagine this would be the problem because the bracket would act as a spacer and give the clearance needed. Anyone???
-Without the AC compressor bracket being there, there's a gap (on the driver side) between the center axel support and the block, putting a couple washers in there to fill the gap.
  • Wanted NA 1ga running and driving
    I'm in the market for a N/A 1ga Dsm preferably running and driving that's manual. no preference...
    • Nii
  • For sale 2g 7 bolt engine build parts and mounts,
    New lowered prices on everything!
    • beegeezy
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
