Axle help
Craig1970
48
9
Sep 9, 2016
Warren, Rhode Island
i am trying to replace my front axels but i need help identifying what year this would have come from , this is what i can tell you about the car it started life as a 98gst but had been heavily modified awd swapped ,6 bolt swapped , among other things i may not have figured out yet.
so if anyone knows what year or model that would match this would be really helpful
Please elaborate. What is the problem?
Fws is a one piece axle. Awd axle is two pieces. The bracket and length of the intermediate shaft is different depending g on auto or manual and what year. So please show us your issue. If you are awd converted you will need that two piece awd axle for the drivers side. There is some interchangeability depending on what else was Installed. The differences in years is the ac bracket. You will need to know what you have.
i thought i kinda did elaborate i am looking to replace the drivers front axe,l that is what it looks like , the car is a 98 originally a gst that has been AWD swapped and 6 bolt swapped but i bought a gsx drivers frond and it looks nothing like that
so the question fully is which one matches that axel
ok so i went through rockauto and bought a AWD front drivers axle and this is what they sent
I recently replaced that same axle on my AWD 2g. Be careful when separating the axle from the intermediate shaft, the bearing kit for the bracket is essentially discontinued at this point so replacing the bearing or seals could be troublesome if you damage them during separation. Here's a good writeup for on the individual bearing/seals just in case they get damaged. https://www.dsmtuners.com/threads/intermediate-shaft-bearing-replacement.428844/
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
