i need axle help!
1g93gst
157
7
Aug 12, 2009
nt, NU, Canada
just got a 2gen transmission that will be going in a 93 fwd turbo eclipse! now i know i need to do a few mods which are basically done. but i had NO IDEA the axles would not fit!!!! as i was also told the 2gen axles are a bit longer. my question is can i use 1st gen awd axles on a fwd? someone said that awd axles fits perfect in a 2g trans. i really need a deffinate answer thanks guys.
why are you using a 2g tranny?
Why must you try to add a rediculous comment to a serious question???
Im wondering if you need to use the axle cups out of a 2g and fit them with the rest of the 1g axle... I wish i knew more but im sure someone will chime in.. Good luck
thanks for the reply. yea i was wondering that too. the spline seems way too small on this tranny.
someone has to know? really? comeon.
yea i heard awd's work but not the fwd so im wondering if this is even possible anymore. maybe the 2g transmission can only work in a 1g awd....
sorry to bump this back but i just recently heard that 93-94 axles will fit. i had the smaller axles on the SPZV transmission which im guessing is a 90-92 if anyone knows anything and would like to share that would be a help. also if your selling a set of axles let me know :)
