axle grease
ceth17
87
Feb 23, 2010
lubbock, Texas
do i need to put axle grease in th axle hole were the Tcse is and on the axle, if so what kind of grease
You don't NEED to but it will help a little with the installation. Its always a good idea to put some anti-seize on the axle splines that will be going into the wheel hubs also, so next time you pull them out you won't have to deal with stuck axles.
I usually just spray splines with a little wd40 on install to make things slide a little better. Can't say I've ever had one cease up at the splines before.
