axle cuff question
cj8990
97
Mar 20, 2010
Chicago, Illinois
Are the front axle cuffs the same for fwd and awd? I know the axles are different but are the green cuffs the same? Doing an awd conversion and i have an awd one seized in the hub but my fwd one came out easy so Im wondering if i can pop the cuff off my fwd drive one and use it with the awd axle and a new boot?... this is for the outer cuffs but Im also wondering if the inner ones are the same as well?
Yes they should be the same. The only difference is obviously in the actually shaft because the drivers side has the bracket that attaches to the block for AWD. Are you running ABS?
