AWD TSi leaks from transfer case where would it leak from- how to fix?
sepulchral
61
Dec 9, 2005
midlo, Virginia
Where would it be leaking from and how can i fix it? I think its coming from the driveshaft.
There are 3 common leak points. Driver's side axle seal, passenger side axle seal, or the transfer case yoke. Is this tranny fluid that is leaking or transfer case? ( They should be significantly different enough to tell by touch ). If it's tranny fluid, it's most likely one of the axle seals. If its transfer case fluid, it's most likely the yoke/rear seal leaking.
