AWD rear subframe bolts part number
AlphaVision
297
Jan 28, 2007
Sofia, Europe
Hello,
I am doing an AWD swap but I cannot find the part numbers of the 2G rear AWD subframe bolts. I have them on my donor car but if they cost cheap I prefer buying them instead of all the cutting.
Hello,
If you are looking for the 4 nuts that hold the subframe to the body they are PN mb242260
a lwr stopper qty 4 PN mb948077 and upr stopper qty 4 PN mb948078
if you mean the diff mounting bolts they are qty 2 pn mf106149 & qty 1 mf106157
if you mean the 4 studs that hang down from the frame rails that the subframe mounts to there is no PN for those, so use lots of PB blaster.
Hope that helps
I feel that it was a benefit to cut them from the car, as it was great practice to cut into the recieving car to be cleaner as you know better technique and location.
Paul, i believe that is true.
OP, you can purchase new grade8/class 10.9 bolts that will do just as well
  • Wanted 6 bolt NT water pipe
    • chrisman287
