turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Because of my disability (left leg and back issues) and the fact that inconsistant clutch release has plagued me lately i just had a few questions
1.) learned myself what i need on this one continue to Q # 2
2.) with a car that has full stand alone EMS, what kind of signals are needed to run the trans without it's original TCU ? (i have outputs for TC lockup, but what signal types control line pressure and daily shifting?)
3.) is it only under high line pressure that down shifting sucks on these?
4.) How many of the mounts are different? is it just the top main one on the pasenger side?
5.)i KNOW the speed sensor is different but will the speedometer read accurrate in a 5spd car pullling from an auto speeed sensor?
6). maybe the most important how much heavier and harder to get in and out is this compared to the 5 speed (my crippled ass wana know)? I usually consider autos easier in other cars because there's no clutch splines to align, just making sure the converterstays alll the way in the trans/pump so it doens't chear the dogs off the pump is the main worry on those in other cars
7.) CAN i pull the ring and pinion from the auto rear diff and isntall that in my LSD rear 5spd unit (or vise versa install the LSD unit into the auto's housing and use it's ring gear on the LSD diff?)
8.)How well can you launch on an OEM 2g converter and what about clutch life on an OEM 2g trans with 450+ hp to it daily? (i do have anti-lag, two-step and nitrouse on the car currently)
9.)will my 5 speed front and rear axle/CV's work in the auto trans or are they different
I have an 95 drivetrain so since they are very different in some years i figure that is important info bein that my car is a 97
anyone interested in trading a 5sp setup for an auto
sucks cause i've always wanted to feel that 67mm turbo pull hard at 30psi through a few gear without ever letting off the thorttle.. i third it already feels like you're on an airplane taking off
