Mahreeoh17
5+ Year Contributor
- 272
- 267
- Jul 12, 2020
California
Just a quick question. Do 96 swap parts work on a 99 FWD? Not sure if it has to be 2GA and 2GB specific.
Yes. We have used a 95 talon donor to make a 99 gst into awd. The rear knuckle has 2-3mm less clearance due to the arch of it. This only matters if trying to fit aggressive offsets. Most will not be aware or ever even know.Just a quick question. Do 96 swap parts work on a 99 FWD? Not sure if it has to be 2GA and 2GB specific.
Yes, just make sure the axle gear matches the transfer case. I believe 97-99 have different ratios than 95-96. Definately don't want to get those mixed up.Just a quick question. Do 96 swap parts work on a 99 FWD? Not sure if it has to be 2GA and 2GB specific.
Yeah it's a matching set. Is one any better than the other?Yes, just make sure the axle gear matches the transfer case. I believe 97-99 have different ratios than 95-96. Definately don't want to get those mixed up.
Let me correct myself for future DSMers. The tranny and transfer case must match. I believe the rear is the same on all models. And no, they serve the same purpose. Really don't tell a differenceYeah it's a matching set. Is one any better than the other?
I also used 96 parts on my 98 Spyder like state above just match the transmission and tcase you'll be set. I'm actually going to try and source some knuckles from a 98-99 for the extra clearance in the rear.Just a quick question. Do 96 swap parts work on a 99 FWD? Not sure if it has to be 2GA and 2GB specific.
