qendrim
- 36
- 0
- May 19, 2007
Ancaster,
i have a 20g, and lets not go there...
my question is on a 4g63t engine. upgrading the 14b. what turbo can i upgrade to, without touching the injectors n installing the SAFC. I HAVE A WALBORO 255LHP FUEL PUMP, CAN STOCK 450'S HANDLE A BIG16 OR CAN THEY ALSO HANDLE EVO3 BIG 16G??????
I WANNA STAY AWAY FROM SAFC N INJECTORS!!!1 ### reply and let me know ASAP witch turbo is perfect n that i wont have to touch injectors nor have to do anythin with safc!!! thnxxx
at the mad tyte comment....to the op and anyone else that is saying "just stick to this (insert number)psi and you will be fine".....boost is a relative number....the term boost is actually a representation of the pressure in the intake from the air that is NOT getting into the combustion chamber....CFM is what is concerned with how much actual air the motor see's under boost....for example....aside from the heat that is generated by the small turbo's (13g/t25) you can run higher boost numbers than the bigger turbo's *on the stock fuel system* (im running about 17psi on my 13g with no problems) simply because they flow such a small amount of cfm. the bigger turbo's (for example the 20g) flow a considerable amount more cfm so the amount of boost naturally has to be much much lower because the cfm is so much greater*on the stock fuel system*. Make sense? And all the fuel cut comments are irrelavent....how much do we have to go through this? Fuel cut has nothing to do with "out running the fuel setup"....that is all based on airflow through the mass air
although I have yet to run into fuel cut when no boost leaks air present (shrugs shoulders)
nd i didnt think it would matter that much (dont laugh), and i also have a turbosmart BC it dosent work very well, can i remove it and make straight T hose joints??? witch would give me factory boost correct????
say it with me .............woooosaaahhhhh..........its just boost what you skurred of???
