Average Vacuum while driving
93GSX4me
39
Oct 30, 2006
Federal Way, Washington
Ok so I've searched dsmtalk.com and dsmtuners and only found obscure references to owners average vacuum readings at vertain points ie idle and driving
At Idle I get around 12-23 Vacuum readings
while cruising with no load ( maintaining - not accelerating ) 15-20
Pretty much an average of 18-20........
Is this normal ? What is a normal vacuum while under no load ? I need to know what to reference while looking for leaks.... If this is average then ill be wasting time looking for leaks that dont exist LOL .
This concerns only 4G63T ( turbo - not 420A with turbo conversions !!!!! ) :dsm:
Yea that seems around normal, at least for what I have seen. If your that concerned about a leak, get a boost leak test done.
well instead of starting a new thread ill post here
anyway i have a 98GST and i've recently started having some wierd vacuum issues. I use to get about 18"hg at idle(850-900rpms) but now when i come to a stop i sometimes get as low as 15"hg usualy but it slowly creeps up to 15"hg from 19"hg over about 8seconds or so also during this time my idle gets a little lower(usually around 680-700) if i tap the gas it goes to -22 while it decels till it hits idle then slowly goes to 16 or so.
I've done a boost leak test and found i do have one from the biss screw (no cap or o ring =/ but hasnt been since the motor put in)
now only thing that comes to my mind is that the idle might be what is causing the lower vacuum cause i have had a idle control system CEL come on a few times (4 over 15kmiles)
also i recently moved there is quite a bit of elevation change 2700 to 1000
so im just wondering if i should be concerned because i know i should have 18+ vac at idle and what should i look for to cure my problem.
also this doesnt always happen (most of the time) but sometimes ill go for a drive and ill have normal vacuum and my idle will sit around 800 and not fall.
