Average vacuum readings
Status
Not open for further replies.
Eclipsemblue
356
May 8, 2004
####DSMTUNERS, Maryland
hey guys i was just curious what the average vacuum is i have a 420a and im reading 12 vacuum at idle and i was wondering if that sounds ok. Cause i dunno if im running incorrect boost levels :/ cause if my vacuum isnt reading correctly than my setup for the gauge has got to have a problem somewere. Gauge is fully functional reads diffrent levels of boost and vacuum under diffrent pedal pressure.
I believe that is is usually around 15 or so. The reason that your vac would be off would be because of a boost leak somewhere so try that and see if you have any leaks.
i have the boost gauge hooked up from the TB and since the turbo has just gone in we went over everything checking for leaks, my boost gauge however makes a sssssss noise, im not sure if the hose that connects into the boost gauge is fully on.
i have this skinny little clear tube made of like plastic i think imma trash it and get a nice big rubber hose run it and see what kind of vacuum readings i will get.
You current elevation has a big bearing on idle vac it seems. In southern Wisconsin I get 19 or 20Hg vac at idle.
ok guys this is how i have my boost gauge setup, if its wrong please correct me cause i dont want to blow my engine on a false boost reading. The other pic is of my car running at idle vacuum level.
my vacuum line that was going into the boost controller wasnt fully in i guess. i adjusted it and now im reading 14-15psi vacuum.
Status
