AC cause lower vacuum readings???
Module Unknown
557
Nov 27, 2001
Elk Grove, California
So it was a bit warm out today and I was cruising around with the AC on when I noticed something while sitting at a red light. My vacuum reading was at 15. Turn AC off, back up it goes to 18. AC on again, and down it goes. Is this normal? I don't recall noticing this before, but then again I haven't used the AC for a while.
If that is normal, could someone please explain to me why that happens. I'd like to understand what's going on.
Thanks. :)
This is normal...
the vacume the engine pulls is directly related to the load on the engine. Hence when the ac is turned on the load increases and vacumme decreases.
