autometer wideband install questions
newtodsm's
142
Jul 9, 2009
waterford, Michigan
i just abought my autometer wideband o2. my question is that the directions say that 2 wires run to a datalogger which i dont have. is there any other way to hook it up? also can i put the o2 sensor in place of one off the stock o2 sensors? i still have my factory exhaust
if your not using a datalogger dont worry about those two wires, just hook up your power and ground wires to the gauge and install your sensor in the rear O2 sensor(not the best place, should have an o2 bung welded in before the flex section) and you'll be set to go, just be aware that the sensor will be a tad laggy that far down the exhaust stream. Alos if you havnt done a boost leak test on your exhaust it would be a good ideal pretty much you dont want any air leaks before the sensor or it could through the reading of the sensor towards lean.
ok cool im going to do a boost leak test when i get it back from the trans shop. i will have a bung welded on when i get my new exhaust. thanks
