2G Automatic trans differences?
TJCTalon
953
98
Aug 20, 2009
Nebraska
I am confused on what the differences are on our auto DSM transmissions. So I understand Tcases need to match 95-96 transmissions and 97+ need to have the matching 97+ tcases. Is that just a manual trans issue or is it the same for auto's?
How can you determine the year on an auto trans? I bought a used transmission 10 years ago, and I have no recollection on what year it came out of. Im hunting for the last 2 remaining parts I need for the manual to auto conversion. I still need a Tcase and the rear diff. So I just need to make sure im finding the correct matching parts.
Thanks for any help!
Same with autos…. They need to match. I have auto tcase 91-96 and 2G auto LSD diff if need. 2G autos rear diffs are all the same 95-99 as long as you have the right axles LSD or Non LSD
You need to take the front differential out and count the teeth. 91-96 auto case has 72 tooth front ring gear
97-99 have 71 tooth front ring gear
More info on www.w4a33.com
Awesome man this is exactly what I needed. I just went out and looked. Appears I have a 95-96 trans.
You should get rid of those hoses and clamps. Go an fittings. Amazon has everything you need. You can remove those barbed fittings and replace them with -6 an fittings. M12x1.25 is the thread pitch for the trans fittings.
I have the fitttings(new) and tcase/diff no point just buying the fittings off me but if you buy a diff or tcase all throw the fittings in for free..
Also have other auto parts transmission parts if you need all oem
Yes sir, I have a b&m transcooler I need to make some lines for. That's the plan at least. First things first I need to find the last 2 important parts I'm after.
