Automatic AWD Front Axles
AK Thunder
117
Dec 16, 2008
Anchorage, Alaska
Ok im having one hell of a time finding the right information.
Both of my front outer CV axle boots blew and now the bearing cages are toast :banghead:, so im in the market for new CV axles.
I dont have much of an issue looking for the passenger side axle, but the driver side half shaft... not so lucky.
Now my question.. Will the driver side half shaft from an manual trans fit in the place of an auto trans half shaft? from what ive looked up (been at this for about a month now) they should fit :pray:, but i dont want to order a half shaft only to find out that it wont fit:notgood:
i just swapped axles in my Auto AWD. i used axles from a 5spd that i parted out. HOWEVER you will have to reuse the inner driver-side shaft that bolts to the block (from the AUTO). I forget what that part is called... If you have just axles from a 5spd you are fine, if you have the whole assembly(from a 5spd) on the drivers side you will have to do the swap...
help??
tim
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
